I will be when I get a chance, going to use AMSOIL in both. Using the Signature Series ATF and Severe Gear in the correct viscosity.
I'm hoping changing to synthetic will help with my winter mileage.
edit: Looks like the 75w-140 is already synthetic, though the transfer case it's hard to tell and looks like it may not be based on the viscosity # I found.
By the time spring rolls around I'll be due on my 2019. But in previous years I've used Mopar 75W-140 (MS-8985) gear oil, which is the heavier duty lubricant for the differential, and the Mopar Limited Slip additive (MS-10111).
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
