2021 ram limited wheel rub solutions
Badger79
Looking for solutions to some wheel rub. 22” stock wheels, ram air suspension : Cooper discoverer STT Pro 35/12.5/22
2” hubcentric wheel spacers?
2” Mopar lift kit?
thanks for any information provided.
Rubs at full right or left turn in normal suspension mode.
pictures are in exit/entry mode.
I wouldn't want the spacers due to the dirt being flung up on the sides constantly. If the 2" lift works fine with the air suspension and doesn't make the ride harsh I would go with that. For this reason I went with 33" tires that only rub at full lock on a curb drop in Normal.
I'm pretty sure the mopar kit doesn't work with the air ride, and all the lift kits I see are 5"-6" kits. Just leave the truck in the tallest setting and it shouldn't rub. Or depending on how bad the rubbing is, break out the grinder and sawzall and start cutting away where it rubs.
2” Mopar lift kit?
Ok just an update, cut away some small amount of plastic from wheel well and drives perfect now in normal mode, really liking the 35 in. tire look too. Now for speedometer recal.
You were able to get 35" 12.50s on without a lift/level? Im on the cusp of buying some tires and want to go as big as I can without causing too many headaches.
