Before and After 3" Leveling Kit
Jlast55
I just purchased the kit below on Amazon and installed it on my 2019 1500. Install is fairly basic, took a bit longer than expected because I had to go buy a pickle fork halfway through the install (rookie move), it took quite a bit of effort to jar the nut from the upper Arm with the pickel fork. Looks like you need at least a 4"-5" lift to get a prerunner look with the front suspension higher than the back, will need to get a real lift kit to accomplish this. Pretty good install video on youtube posted below as well.
WULF 3" Front Lift Kit for 2019 Dodge Ram 1500 4X2 2WD Suspensions Leveling Strut Spacer
http://a.co/d/4mbZ7aJ
IMG_20180930_093644.jpgIMG_20181002_091016.jpgIMG_20180930_093751.jpgIMG_20180930_180735.jpg
Nice job thanks for the write up
Looks good, what size tires are you running?
It looks like you netted about 2.5" of lift if I'm seeing this correctly?
How’s the ride? I’m thinking of doing the same 3 inch level but the ride is soo smooth I’m on the fence about it
