installing rebel OEM suspension on 2020 (DT) big horn
Streetsweeper
Hi all,
I'm planning to install a rebel suspension on my 2020 big horn (DT).
Apart from the shocks & springs, are there any other parts I must have? I assume both the front & rear sway bar links are probably both longer to accommodate the extra 1" lift.
Anything else I must have?
didnt swap end links in mine. did nothing but shocks and springs and everything bolted right up
Is there any difference between the shocks and spring on a Rebel or a Ram with the off road group?
springs are the same, the Rebel gets Bilstein shocks, the ORG gets the standard Off Road Hitachi shocks
