MDS on 2020 Laramie
Jowilly66
I cannot determine where to turn on MDS.
I checked settings in UConnect, but cannot find option.
Are all 5.7s supposed to have that option?
2020 Laramie
It's "on" all the time and will activate given the right driving conditions unless you set your gear limiter to 8 using the paddle on the steering wheel to deactivate. You can go in the settings and turn on the ECO light which will tell you when MDS is active. See the video posted above to find the option.
2020 Laramie
It’s just a light (“fuel saver display”). You can’t actually turn on/off MDS.
2020 Laramie
As mentioned, MDS is always on. You don't need to do anything to turn it on. There are ways to temporarily disable it though.
OMG. HOW MANY "MDS" THREADS ARE THERE NOW?????????? Its just the same information repeated over and over and over and over and over again. Use the SEARCH function!
