Biggest tires on stock 2019 Ram 1500 Laramie 4x4 stock
Tempu
Hello Guys wondering if I can fit 285/65/20 on my factory wheels without rubbing or interfering with functionality on my 2019 Ram 1500 Laramie 4x4 stock.
any help will be appreciated
Bulldawg23
Do you have the off-road group?
mikeru82
5thGenRams Supporter
The Palouse
That's 2.5 inches bigger than stock diameter. I can't say for sure but I suspect they would rub if your truck doesn't have the ORG. I've read they will fit if you have the ORG since it has a 1 inch factory lift.
gHiDoRa
Elvis Presley
Op stated 4x4 => ORG
That is the tire size i want go with too but i think it will slightly rub.
arod412
NJ
He can have 4x4 but not the off road group. That is a add on from the factory with skid plates, heady duty shocks ) don’t know what this means over stock ones...but I know it gives it a little more height...maybe between 1-2 inches higher than stock.
I have a 2020 Laramie but it doesn’t have the off road group package. I’m trying to get a rough country 2” strut on mine so I can fit bigger tires on my Laramie.
Owner of a 2020 Ram Laramie, 16 Dodge Charger scat pack and my wife 21 Jeep Wrangler Unlimited Sahara
Ramjeep
I have this question too. I want to get Ko2's sometime next year and will probably get this size. I have a Laramie with ORG. Anybody have pics of this set up ?
arod412
NJ
From other threads...the big ones are KO2, Falken wildpeak at3, duratrac, general grabber...so you can't go wrong with any of them. For me, it would come down to price. I'm definitely down with K02.
Owner of a 20 Ram Laramie, 16 Dodge Charger scat pack and my wife 21 Jeep Wrangler Unlimited Sahara
Ramjeep
thats my thoughts too. I had Ko2's on my Grand Cherokee and loved them. I'm also hoping the bigger tires will help with the rake in my truck I hate it !!
arod412
NJ
So I’m trying to find this tire size (285/65/20) has anybody seen any Black Friday deals?
Finn5033
MN
I’m not sure exactly what you mean with this? Different tires are not going to change the rake of your truck. Only a leveling kit will do that. Unless you just mean you hope the bigger tires will make the rake not as noticeable?
Ramjeep
Yes that's what I meant . Sorry this is my first truck. Hopefully the bigger tires will make the rake less noticeable. I'm not ready for a lift just yet, maybe in a few years.
MarvsAMartian
Canada
Check out customwheeloffsets.com they have a gallery you can punch in your trucks specs and see others who have run that size in different tire brands/different wheels. Stock wheel height on the RAM is 32". You should be good to go up to 33" depending on the offset. I've seen some guys stuff a 35" in there but it's mixed on whether they needed to cut/trim/modify at all. Some say they don't. Others say you have to. If you also have the ORG (1" lift) then 34's should be doable with 35's possible.
Ramjeep
Thanks !!Man I love this forum great advice. Yea I have the ORG so from my research 285/65/20 should be right at 34".
realralfy
I can speak to this...I had that exact size on the standard suspension and stock wheels. There was some rub at full steering lock both directions on both sides... Did a 2" level amd its gone..
arod412
NJ
Any pics of this? Would love to see how much of a wheel gap is left.
realralfy
Here are pics before and after I put on the Fox Coilovers, gave it a 2" level ...apologies for the dirty truck
Scram1500
If you aren't ready for a lift a cheap easy way to get rid of the rake is a "reverse level" by dropping the rear using 2 inch lowering springs
James1414d
Portland Or
I have them on mine with a 3.5" lift and stock wheels. They rub when I'm fully turned a bit. I'd have to guess that they'd rub quite a bit at stock height.
