Installed rear spacer now have a "click"
19newfieram
Hi guys. I installed a 2"5 inch front level and 1 inch rear spacer with ready lift HD air bag kit. When going slow over a "speed bump" type of ripple in the road I am getting a metal "click" from the rear passenger side . Any suggestions would be greatly appreciated .
Tks
Did you find the issue? I would think it's your UCA making contact with your coil spring (at full droop) with the way you described the metallic "click." Wondering what you found...
Still in discussion with Air Lift. But some some reason the spacer on top of the bag is going up and getting stuck in the upper part of the spring. Only happens on one side. Back and forth with Air Lift for 2 weeks...driving me insane.
