substance on coolant Check Stick
busa2009
Atlanta, Ga
i randomly just checked my coolant overflow tank and the stick had some weird substance on it not for sure what it is...Its def empty wondering what type of coolant is needed for this truck cant find it i use to know but forgot im sure you cant mix colors though..........
I know mixing green and orange coolant will cause issues similar to this. The coolant in my ecodiesel is purple/pink depending on if it is hot or cold. Not to sure about the hemi. I think it is called OAT coolant.
Also, there is no dipstick on my overflow reservoir.
what do you think of that sludge that is on the coolant stick?
I don’t think it is normal and would probably do a coolant flush or visit your dealer if it’s still under warranty. I’d think powertrain warranty would cover this but who knows.
I have 47,000 on it and have the moper extended through Ziegler I’ll check on it. It’s def not oil
I went thru this earlier this summer. This is the way it was explained to me at the dealership. The 19 Hemi's and beyond use a 10yr/150,000 mile antifreeze. Mopar part # 68163849AB
The previous years used a 5 yr/100,000 mile antifreeze Mopar part # 68051212AC
The auto stores I visit knew nothing about the difference, didn't stock the newer stuff.
Do not mix the two. They are not compatible.
I don't know anything about the eco diesels and their cooling setup.
Be sure and ask the right questions of the right people and double check the part numbers to be sure.
Whatever that sludge is, it definitely does not belong there.
this is what i drained from rad
the number you gave for the 10yr/150000 is for 50/50 the one for concentrate i will post pic
Mine has it, and I'm at 61k. I'm pretty sure it has something to do with the astronomically high temps these run at.
Was this fixed under warranty? Coolant flush or whatever, just looked at mine randomly and had the same sludge or dirt seemed like
Busa did the dealership fix this for you under warranty?
