Toyo Open Country 35, will they fit?
darthvaper04
I’m getting some 18”NV Methods 18x9 with some Open Country 35x12.5 and about to get my level done. I did some research of people saying they will fit they won’t fit so I just want to see if anyone is running that same set up before I get them. Thanks in advance for the help.
I think the 12.5 width gets dangerously close the the UCAs you might want to look into Bora spacers to be on the safe side, some members had success with 295/65R20s
What’s the rim offset on the Methods, -12? With stock rims, Zone UCA’s and the stock Falkens it was damn close to rubbing the UCA’s. Barely got a finger in there.
I had 275/65r20’s (34/11) installed and it’s even closer but it still clears. I think the negative offset will help.
Did you check CO gallery? There has to be people running that setup.
What’s CO gallery? Thanks
Custom Offsets website. Look up gallery and you’ll see just about every rim/tire lift combo
