Acuator Motor noise under truck..
yankeefan31569
anyone ever shut her down and dismount after 30 seconds or so and hear a acuator motor in the rear under gas tank area? heard a few times after prking and getting out...just curious
I think you’re speaking about the parking brake. Mine sounded/sounds the same. Disable auto parking brake and see if the noise persist. Mine went away once I disabled it.
Do you have air suspension?
Funny you brought this up, just heard the sound yesterday getting gas .
If you have air suspension and pull on the door handle when locked and the fob is not near the truck the suspension resets itself. I keep mine in aero mode all the time and this happens. It’s normal.
Just heard this for the first time yesterday. Freaked me out. I thought it was the fuel pump shutting down.
Because of the timing, it is probably the electronic rear e-brakes being applied. This is normal.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 03 June 2018. Now at: 041868 miles.
thanks man... im not going to worry about it...
Regards,
Dusty
Regards,
Dusty
Just heard this tonight. If it’s the e brake being applied, shouldn’t it do this every time you turn off the truck and get out? I hadn’t even locked the doors yet.
Yeah, I'm not sure what it is but it isn't the e-brake. Mine does it too, but I don't have the auto e-brake set to engage.
Not sure how mines set at the moment. But definitely don’t hear it every time. Is the it the evap?
Once in a while I hear it.
Maybe it does it every so often to keep the cables and moving parts from 'sticking'?
