JL powerwedge sub
LLkoolskillet
Im looking at putting in a sub behind the drivers side passenger seat. I have the standard 6 speaker setup in a 20 bighorn crew cab. I want something all in one that has good sound. Ive settled on the JL powerwedge box. I wanted to go 12" but it looks like the box is to thick (6-5/8" (7-3/8" including grille) to fit behind the passenger seat. The 10" is 5-1/8" (5-7/8" including grille) Below are the links to what I plan to buy. Is there anything else I am missing?
https://www.crutchfield.com/.../JL-Audio-ACS110LG-TW1.html
https://catalog.pac-audio.com/.../audio-interfacing/lp7-2...
https://catalog.pac-audio.com/.../amplifier.../anc-ch01
https://www.crutchfield.com/p_1.../EFX-PA8BX-Wiring-Kit.html
I was looking at these as well but the measurements would not fit under the rear seat. Where are you putting the box? You said behind the passenger seat? I didn't see any way to make it work without poking out somewhere.
In this thread, hes got a similar box mounted behind the seat upright.
10-4, I didn't know there was room to put this type of box there, I was looking at the kicker for this area as it is thinner.
I looked up the pioneer box and the dimensions are almost the same as the JL so it should fit. I just want to know if everything I listed is all I need LOL.
I also saw that kicker but stumbled on the JL.
