Crew Cab Subwoofer Boxes..
BilletLaramie57
TN
^ I was just about to say it’s probably to stop orders from coming in without having to shut everything down. Happens often with eBay sellers. Inflate the price and boom no sold products unless you have that one person where money is not an issue.
Could you imagine they come into work on Monday and there are 15 new orders lol...
PurpleRT
In that case lol they getting bumped up in the que obviously somebody wants it a bit more then others.
Daverox123
Where is everyone mounting their amps? And what amp(s) are you using for 2 10s. I’m still debating on what box to use, probably gunna use skar audio for the subs,
Ellisstrong
Atlanta Ga area
My amp is where the factory sub was. I used a jl1500 watt amp on 3 10’s
Trizzytexan
Here’s my box. Sealed with 3 10’s.
Did you have to get your 3 sub set up custom made? I have been trying to find a box for 3 10" subs and cant find any, and yours is the first Ive come across, went to fox website and don't see it on there either
Trizzytexan
Okay I see now that you got it from MTI, couldn't have been cheap, looks like a custom build?
Ellisstrong
Atlanta Ga area
The box itself was like 900 or 950 but I caught them during a 30% off everything sale. Last year Black Friday they had 35% off of everything so if you are thinking about it I would say waiting until then could be worth it. I think you could get them to make this same box in stage 1 with just carpet for at least a couple hundred cheaper but I wanted it to match my interior.
NOLA TBOY
I have FOX Acoustics 2-12 ported with 10" adapters and could not be happier. In my 4th gen I had his 2-10 ported and only switched due to the new layout in the 5thgen without storage bins. I was one of the first to get FOX's 2-12 box V1, only downside is it covers up my storage bins. I have the MOPAR all weather mats and it sits fine on top of them. My amps fit fine behind the box under the back seat. Pics were posted on thread below post#370.
https://5thgenrams.com/community/threads/5th-gen-stock-stereo-upgrade-options.926/page-19
vazzue61
What is a good box suggestion for two 12” subs for a ram 2020 1500 crew cab
Yams2k20
Are you guys running your amplifier power wires down the drivers side?
I'm going to be installing an amp in a few days so any tips on snaking the power wire through to under the rear seats would be greatly appreciated.
I ran mine down the passenger side, and tapped the LCI on to the factory sub output
Yams2k20
Frostbite sub box. I built my own and would have been easier to buy, was my first go at building a box with so many angles. I should have left it to the pros.
_mr_white_
ALRIGHT GUYS! THE DEAL IS LIVE! FIRST 15 PEOPLE TO COMPLETE THEIR ORDER, GET THE 15% OFF GROUP BUY DEAL!
I’ve teamed up with FrostBite Audio Enclosures, for a single 10” (sealed) subwoofer box for Crew Cab trucks. This box is designed to only use the floor space under the longer portion of the backseat..instead of using the entire floor space. This is perfect for folks like me, who would still like to be able to use the available space, with the seats flipped up..but also want to add a little bass to their music. But also don’t need the overkill of two subs.
The box is available with a single standard circular 10” cutout, but a square set up is also available for Kicker L7’s. It’s got 0.6 CU FT of air space. The deal for this Group Buy, will be 15% off of the $339.99 retail price..box only. Subwoofer options are available from them directly as well at an added cost. Photos display a red box, but there are various other color options available as well.
Here’s the link! If you’re interested, jump quick, because I don’t see this group buy lasting very long!
View attachment 58339 View attachment 58340 View attachment 58341 View attachment 58342 View attachment 58343 View attachment 58344 View attachment 58345
Did Frostbite go out of business?
IndianaRam
Indiana
Just finished building my own box. I wanted to keep the storage bin under the back seats so this was my only option. Took awhile to build since I’ve never done it before but happy with the way it came out. Box has somewhere around .57 - .59 cu.ft. Volume.
Using: 1-10” JL Audio 10W1v3-2 sub & Sony XM-GS100 amp.
When I have time I will install it.
Ratm0987
Someone with the fox 2-12" box know what the mounting depth is? I'm needing something with at least 7.2".
Cleatuspiglet
Trying to decide on a box for the 5th gen Ram.. any insight would be appreciated.. I have 2-12"s and amp currently and I am open to changing subs to different size if need be for a good box. Here's my options that I know of and also like. 2 boxes from FROSTBITE and 2 boxes from Fox Acoustics..
I've also got the fox 2 10" ported down firing box in my truck with 2 Skar audio sdr 10's & it's sounds amazing. I have people asking what do I have in my truck & when I tell them it's 2 10's they're in disbelief and of course I have to show them.
