285/55/22 Installed on OEM Wheels
JeepNickInPA
Finally getting around to post pictures of my new setup. Vehicle is a 2020 Big Horn with the night package.
- Initially I had installed the Nitto Ridge Grapplers 285/55/22 on the factory stance. Technically I could have gotten away with this setup as there was only a slight rub at full wheel lock.
- They looked a bit stuffed so I decided order a Moto fab spacer kit. 3 inch in the front and 2 inch in the rear.
- As for the wheels. These are OEM 22” Laramie night wheels refinished gloss black
- Overall I am very happy with the look. Ride seems to be very similar to OE until I hit a bump/pothole.
-Here’s a few pictures for the forum:
Very nice, do you think you could have gone bigger? I just saw on Rough Country 2" leveler lift for air suspension. I'm very rough on my wheels hitting curbs and whatnot, I'm thinking about going wider and taller on the rubber to protect my wheels.
Thank you! It's actually a "Big Horn." As for the tire size, I don't think I could have gotten away any bigger without going higher in the front.
Did you run into any issues with the rear spacer lift? Did you have to change out the rear shocks or do anything with the track bar?
I'm going to be installing a 2" spacer this weekend and just curious if there is anything I should be aware of prior to starting.
