Rough Country Dual 6-Inch Chrome Series LED Grille Kit (19-20 RAM 1500 Big Horn, Laramie, Tradesman)
Soulkeeper
OH
Anyone put these one, are you pleased? They claim to have a Lumen Output of 2,880. Bright?
While intended for additional visibility, anyone know if you can swap the LED bulb color? I'm assuming they are not sealed.
I have these and I use them as an accent light. As far as swapping them out I never thought of that as installing them alone was a slight pain lol. I have the feeling once you put them in, you’ll leave them as is.EEEB9267-8F72-45FA-8AC0-FBF07E619F12.jpeg
It’s ok, I wouldn’t go out of my way to do it again honestly...
Cutting the grill is required to install correct?
Yes and once you do that, there is no going back...
Shame that section of the grill wasn't simply snap, or clip in.
OK, that's also good to know. I wasn't sure if the bar had a removable face so swap out the LEDs or if it was a solid unit. My guess is, not only solid, but requiring replaced when something dies.
Thank you.
Not a problem, anytime that I can be of help.
Yes sir, it’s controlled via Bluetooth on my phone..
I’ll have to find the Bluetooth unit app. It’s a $90 piece that you wire up between the lights and dash. They add that app to your phone and presto, you have Bluetooth without having switches. I also have a switch just in case I’m in an area where Bluetooth does not serve me well.
Here is a photo of what I used.
