Post your Rebel pics!
I've been driving Rebels since 2016, and I haven't gotten tired of them at all!
What rack is that for your kayaks? Is it easy to put on/take off? Looks like a great set up for what I want to do.
I had to modify one to fit the rambox. I just cut the support bar that would go across the top of the rambox and made new brackets. No one makes one for the RamBox 20200824_165711.jpg
Its from ACI. I had to modify it. To still be able to use the RamBox. I cut the support bar and made new brackets. I made it so its easy to put on and take off. 20200824_165737.jpg20200824_165711.jpg
This is awesome, where did you get the emblems from?
Looks like I have the same ones that I picked up on ebay
Where did you get your rack for the bed? I was wondering if anyone made one for the Rambox models. Also is it bolted down so that it can be removed?
Dethloff also makes one that's really nice, but my understanding is it's not that easy to put on and take off.
Scroll up and you can see bracket that I made . Yes its easy to put in and take out
I didn't know Bestop was carrying them for 2020's they only show up to 2017 on their website. Did you call them?
It’s actually for an F150. The bed dimensions between the 2 trucks is within 1/4” of each other. Fits really good.
I am actually selling it though. Decided to go a different route.
You must have bought it used to get it for $350.00 What are you selling it for?
It was brand new but unused when I got it. I’m thinking of getting a Go Fast Camper or equivalent.
Installed the Readylift 2” level kit with UCAs. Went pretty well. Tried to do it without pulling the axle nut and the CV joint popped out. So had to go to 3 stores to find a 36mm socket. Once I had that it took about a hour to do the second side and button everything up.
I’ll let it sit for a week and see if the front settles a bit. May end up with a 1” spacer in the rear.
Ordered new wheels as well. Should get those mounted next weekend.
C1794BF8-B97B-4A1A-92F1-20FCA84CCF6B.jpegA908691F-CC67-464C-9D6D-969E03993FEA.jpeg7F64F9F4-DB0E-492F-BE54-900D434C9AE3.jpeg355669BD-2D67-46F8-9945-05F5C9D5831D.jpeg
