deanno33
I've read every thread here related to wind noise in the door / window but it doesn't seem that anyone posted any true fix. I have a 'air leak noise' upper rear of drivers window. Starts around 40 mph and gets louder as speed up. Sounds like window isn't fully up....very annoying right next to your ear when driving. Not overly loud but just plain annoying
At first I thought maybe it was from my window tint but the shop pulled the tint , cleaned the window and seals, same noise. I watch her reapply the tint, and there is nothing they do that would impact a seal. I've been to the dealer 5 times....twice where I left the truck with them.
Nothing worked. Finally, they said it's normal. I drove two other 2020 Rams from co-workers and theirs don't make the noise.
Has anyone else had this issue and found a fix? I looked at every seal. Nothing seems out of place. I've retracted the side mirrors, that's not it. The cab recirc for the AC isn't causing it. Just at a loss. Maybe something I need to live with I guess. I did call another local dealer to explain, and they wouldn't make an appointment since the other dealer had already started the process of fixing it. Said since they had already done things to the truck, they didn't know if their work (the new dealer) would be covered under warranty. Not sure I understand that, but may need to find a third dealer to check out.
- Adjusted my door both in and out in different areas
- Replaced door seal
- Replaced a piece of window moulding
- Replaced window seal
- Made some other adjustments, drove it a lot (25 miles even though freeway is right next to dealer
