I'm sorry, I'm a little confused. You wrote "Fuel Pump" icon. Did you mean Fuel Economy, or is there something that I'm not familiar with?I'll play around with it when I get off this eve and see If I can figure out how/if to re-add it, any direction is appreciated.
On mine that icon is the Low Fuel Warning indicator. I wouldn't think you see it unless you were low on fuel.The Icon looks like a gas pump. It is (was for me) in the menu screen on the left-hand side of the screen that you scroll up or down with the left side of the steering wheel buttons.
See it here on the left hand, stole this image from another member, it's under the highlighted truck front end icon.
Best regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 03 June 2018. Now at: 038460 miles.
AH! I understand now. That area is selectable based on operator desire, so I think you're right.I think OP meant this:
Agreed, this should come back by selecting fuel economy in the setup screen.
This worked, thank you for the directions. Must have unchecked it inadvertently at some point. All back to normal now.Screen setup / favorites menu I believe is where you want to be![]()
Not all but some options can be unchecked. Check them all.
