alwalden22
- Jul 20, 2020
Nice. What are your trailer specs as far as weight? No issues pulling that length? I was trying to keep the length of the ones we are looking at below 30’ but the ones we like are around 32-34’ but light weight.
Thanks for the info. Glad it is towing well for you. I really Like the Keystone Bullets. Pretty light overall, tongue weights aren’t too high and they have the wider apart axles. Which is supposed to help with overall towing and sway.The trailer dry is about 6300lbs.
dry tongue weight is about 814lbs
Towing weight is about 7000lbs loaded.
Overall I am coming in around 12,900 GCWR which leaves about 1k lbs before I am overweight for the 3.21 gear ratio
I am slightly over my payload capacity but under my gross axle weight ratings.
So far I haven't had any issues or errors with the air ride system. I have a decent weight distribution system that has active sway control. I am still adjusting things with the hitch, but overall its a pretty comfortable ride.
Hindsight - Pay attention to the tongue weights you are shopping for. There are 32' travel trailers with tongue weights 100-200lbs less then mine. I wish I crunched the numbers a little more so that I could shop better and save some payload capacity.
My dry weight is about 6300# and with some pots and pans, etc. and a little water in the tanks (they never seem to completely empty) I'm towing at about 7200#. My max is appx. 8300# (3.21 rear end) and the tongue weight is 730. I sagged and sometimes it was hard to tell who was driving, so I added Timbrens in the back and it just hums right along. On the Interstate I run 65 and it's fine. All the temps exactly the same as when I'm running around town naked (so to speak). Coming back from the beach we used some state highways with lower speeds and I got nearly 11 mpg! The trip down on the big highways at 65 it's about 9 mpg.Good looking rig. Glad to hear the 3.21 gears have no issue towing that size
Truck: | Ram | 1500 | Big Horn | CC | 4x4 | 144.5"WB | 3.0L | ||
Tire: | 275/65 R18 116T | ||
Tire load rating: | 2,806 | ||
Fully Loaded: | 2 adults | 2 children | 1 dog | ||
Travel Trailer: | TBD | ||
Truck Weights | Factory | Scales (Fully loaded) | Available Capacity |
GAWR Front | 3,900 | 3,440 | 460 |
GAWR Rear | 4,100 | 2,680 | 1,420 |
GVWR | 7,200 | 6,120 | 1,080 |
GCVWR (Pay+Tow) | 17,134 | ||
Max Payload (Door Jamb) | 1,534 | ||
Max Towing (MyRam Website) | 9,934 | ||
Trailer Weights | Solaire 292QBSK | Apex 300BHS | Jay Feather 30QB |
Hitch Weight | 845 | 672 | TBD |
UVW | 5,893 | 5,975 | TBD |
GVWR | 7,845 | 7,600 | TBD |
Hitch | 112 | 112 | 112 |
Look at the Keystone Bullet as they are lite
Just got back from another camping trip and love our new bunk house. Open range Ultra Lite UT2802BH. It has a lot of cool options. The A/C is whisper quiet unlike our 2 year old Jayco. the Jayco A/C was really loud. It also has a PVC roof and has a 15 year zero maintenance warrantee. I don't have to get it UV treated every year.
Are you looking at the separate BH room version.
I like the idea of the separate room but the ones we looked at the bunks were to small. My 14 year old son is already 6'2". I needed the bigger bunks.
