Help - curious - Larger (Matching Diameter 34.2") Spare Tire test fitment under truck
rsonedecker
So here are the pics of a 275/65R20 (34.2") spare tire mounted underneath. This is the biggest tire I think you could mount under there, and it takes a little extra work getting it up in there. It's really close (1/3") to the track bar, and fits snug in the shields.
Do you think this is too close to the track bar (first pic below)?
19533
19534 19535
rsonedecker
Curious on thoughts on if I'm too close to the track bar.
Yogi217
I wish i could answer your question, but I can't... i have a question for you though, did you have to make any modifications to get that bad boy in there? Any cutting, removing, bending?
Have you had any issues with the track bar since originally posting?
I'm considering buying this size as well.
Sent from my SM-N975U1 using Tapatalk
Yogi217
I stuffed a 295/70/18 in that spot, it’s a bit bigger than the 275/65/20
Any reason you didn't just do 275/65/20? I noticed that's what you are running on your rig.
Yogi217
I think I want to try to get a 295 70 18 under mine too then. Did you have to make any modifications?
Please let me know as soon as you try. I'd love to be able to fit a 275/65r20. If you both can fit the 295/70/18, then I'm sure I'd be good.
Ellisstrong
Atlanta Ga area
I need to know if he had to make any modifications first lol. I want to know how much work it will take before I commit to doing it.
