pber1
- Aug 21, 2018
- Location
- Santa Rosa, California
Anyone know there’s gonna be coilovers for 4in lifts coming out soon??
I’m looking into getting custom length Fox 2.0 coilovers with remote resi’s and custom tuning & 2.0 smoothie shocks for the rear with custom tuning. It’s about $1500 for everything!Anyone know there’s gonna be coilovers for 4in lifts coming out soon??
I haven’t ordered them yet but I was looking at accutuneoffroad.comwhere are you getting your custom 2.0 coilovers
I just sent them an email to see if my plan would work. I don’t need 2.5” coilovers because I don’t off road hard enough to utilize them. I just want to get rid of the 4” spacer, get a Cadillac plush ride, and be able to gawk at those remote reservoirs sitting in the wheelwell lol
Well, I guess my plan won’t work after all. I still don’t really understand why the coilovers can’t be custom made to fit the truck in the factory location, but according to Accutune it won’t work (or they won’t do it, idk). This is the response I got:
- “Well the issue is not necessarily the mounts. As Fox is not just making the mount, the entire shock is custom spec'd. Front the lengths, the fittings, the bolt size on the top hat to the top cap, etc... so there is definitely a whole lot more to it than just taking a top cap from a 1500 Fox shock and bolting it up to a Universal fit shock.”
So I don’t understand why that can’t all be custom ordered? Maybe I’ll reach out to other companies to see what can be done. Or better yet I’ll reach out to Fox directly! I’ll try to post updates when I have them![]()
Yeah I was looking into the Kings on Flithy’s website too. But those are just universal shocks as well so I’d run into the same problem as I would with Fox. King might be willing to completely custom build them whereas Fox might not...idk. But the Kings were about $500 more for the same setup if I remember right, and from what I read I thought the Fox’s were actually a little better made. I haven’t looked into Icon since their valving is digressive, which is better for off road but worse for on road.So king makes them directly, you can buy them from somewhere like filthy motor sports or whomever. You can get them custom length but they are pricey. But then they will be off the shelf king valving, for better or worst.
Icon DOES do this, but last time they said they weren’t taking custom orders yet on these trucks. So not sure if they ever started, doubtful with the corona bs.
Thuren I think is doing Kings too, so he could get them longer too I’m sure.
Hmmm you’re right. Those are 2.5s though, which are overkill for my needs. Nonetheless I think I’ll contact them to see what can be done since they seem like true custom shock builders. Really I just need custom length 2.0 coilovers for the front and off the shelf rear shocks since I’m only lifted 1.75” in the rear. For you guys on the 4” lift, have you measured how much actual lift you got? I got 4.75” lift up front (not including tires)Found it
25001-209A / 25001-210A | King Shocks for 2019 and Newer RAM 1500
King Shocks are direct bolt-on replacement shocks for your Ram 1500 and come tuned by King Racing to give your truck the ultimate on and off-road performance, ride quality, and handling. Custom tuning available. Made in the USA.www.filthymotorsports.com
Possibly, but I doubt it. Fox even makes 2.0 coilovers for our trucks and a 2” lift with the 5/8 shaft (usually for buggies) instead of the 7/8 shaft for trucks. The 2.0 is plenty for these trucks and on road driving. I mean hell the Cummins trucks run 2.0 shocks from BDS and they weigh almost 3k lbs more lolThe 2.0 part might be an issue. They will tell you to run the 2.5 based on truck weight most likely.
Dude the best that I’ve found is either to use custom length King 2.5s all around or (I THINK) the BDS coilovers for the 6” kit would fit if you just adjust the spring preload but I’m not sure. Another member was telling me that Fox was coming out with new front shocks in a couple months and I bet you could get eibach coils to go with them!What’s the verdict chief? I’m ready to go 4”bds but I want coilovers because I got rid of all stock suspension components, so let me know @Mclovinnnnn
