2020 Limited-Gap in bed
Cowlinator
I've had my truck 2 days and quickly noticed a gap in the back driver's corner of the bed where the floor meets the back wall. This is my third RAM and the first I have ever seen this. Clearly not the drainage hole in the back centre of the bed. Anyone else have a similar issue? I can actually see daylight and the ground from the bed! See attached pictures from earlier today. No excuse for this type of workmanship. Will certainly be reaching out to my dealer...
McBroom
That's a designated drain on the front wall of the bed. One on each side
Black 20 Ram
Cowlinator
Black 20 Ram
If that's the case, why isn't there one on the other side. Being a long time RAM owner, have seen nothing like this in a bed.
TX_Phil
Houston Texas
Surprised the bed liner didn't fill the gap. Maybe the bed panels shifted after the liner was sprayed?
Regardless of how it happened it shouldn't have. Absolutely Ram should fix this.
Sent from my SM-T230NU using Tapatalk
SCasey89
See this thread
McBroom
My 18 has a gap in the same spot on both sides. I haven't checked my 20. I will in the am though. I do not have the spray in liner.
Black 20 Ram
MeOff
See this thread
Those are drain holes. Had the same in my 08' and my 19'.
Bellaireroad
Those are bed drains. If you don’t have a one on the other side it has been covered with Bedliner, and you should pick it out
