RAMbox Cargo Management Dividers
Boricua100%
Hi:
I just purchased a 2019 1500DT, and want to make the most out of the RAMboxes it came with. I looked into the dividers, and purchased a dividers kit (P/N 82213988), which the MOPAR store indicated will fit my RAM, but when I tried to install them, realized that they were not designed for my truck model. Upon further research, I found that part number is for the 1500DS model, not the DT. I then looked for the proper dividers, but can only find a divider kit with just the vertical dividers (P/N 82215793AB). The RAMboxes come with what seems like provisions (ledges) for the horizontal dividers, but I cannot find the part number for it.
Does anyone knows what would it be for the complete kit (horizontal and vertical dividers, plus the small bungee nets) for a 1500DT?
j517
Return it make ur own
Rushhour99
Hi:
You just need to return it. It's no use.
Edwards
TX
Hi:
Do a search here. There is a member who makes/sells them for the DT and they fit perfectly with usable cutouts that the OEM versions do not have. And they cost less.
Boricua100%
Thanks for the feedback. I shall return them. What keywords should I use here for the search (dividers, cargo management)??
Edwards
TX
I just searched on "RamBox dividers" and found it:
Boricua100%
Thanks for the help. I checked on the thread, and finally got to the website Capt Joe created. The full set (driver and passenger sides, with horizontal hatches) are selling for $290.
The link is https://www.dtboxdividers.com , and they sell either just the dividers, the hatches separately or as a complete set. I think it is kind of pricey, but it does helps on the Ramboxes organization.
dutchman187
I made my own this weekend for about 15 dollars. Pleased with them.
Boricua100%
I just purchased some black HDPE and will be making them this weekend. Will post pictures once done!
Thanks for the feedback and ideas.
