Stevenc150
- Apr 7, 2020
[This only applies if u have NOT calibrated your truck Odo. to New, larger-than-stock diameter tires]
I put 285/55/22 RG on awhile back. Using GPS i knew i gained around 5mph...which meant my MPG should also be up. But truck mpg readout & my calculations both showed a drop
Then it occured to me...that meant my Odometer reading would be off too!! So using Discount Tire's tire comparison tool [thumbnail]...I now add 7% to the mileage side of the calculation, netting an MPG gain. (Or just figure MPG per normal, and add 7% of that back onto it)
[Example using 350 miles on odometer reading...]
Previously: 285/45/R22 = 350/25gal=14mpg
New: 285/55/R22 = 375/25gal=15mpg
P.S. This also means a 10K oil change is actually a 10,700 oil change
I knew: [larger diam tire] = [bigger circumference] = [each tire revolution I traveled further] = my MPG should get better!
