Best products to get scratches out of paint??? have a bunch of scratches I want to remove thanks
Ceramic coating does a nice job
If you can cAtch the scratch with your finger nail, you might be SOL since you probably went through the clear coat. If it is a surface scratch then a bit of polishing compound and an orbital buffer will clear it up.
Below works great on small superficial scratches. If worse, then move up to a compound/polish. Start with the least abrasive and work your way up to include a DA as necessary. If using a DA, pads vary as well... Wet sanding is also an option, but be careful, especially around edges and creases where the clear coat is the thinnest... then polish as applicable. ED892CB0-C745-4816-B9C8-1D99C0E6676F.png
