Samsonite.sound
- May 12, 2020
2020 1500 Stock 6 Speaker, No Amplifier, No Active Noise Control
The instructions for adding the dsr1 require you to put the Ram in "Program Mode" to add "Amplified Mode" since I have the base stereo without stock amplifier.
PROGRAM MODE - You can do this through a sequence of "Turn Car On - Turn Parking Brake On-Off-On within 5 seconds and you will hear a honk confirming you are in program mode"
AMPLIFIED MODE - "Then once in program mode enable left turn indicator withing 10 seconds to switch to "amplified mode.
I must have tried this cycle for "Program Mode" 50 times" across all the CAN ports and no luck getting into that mode.
I just got off the phone with Maestro support confirming everything is setup correctly elsewhere, but that without getting the truck into program mode to be able to add the amplifier it wouldn't work. He sat with me for 50 minutes as I tried every single CAN bus port (both free and using the T-split for occupied ports) for the DSR1 but I was not able to get the truck to enter "program mode" to add amplified mode.
Any insights on this? I'm at my wits end after 5 days trying to figure this out. Customer service said try different combos of timing with the sequence. But I sense there is something else I'm not doing.
