Air Ride and New Tires
Bizkit
What mode does my air ride 2020 Ram need to be in when I get my new tires installed on the lift?
I thought so. I just didn’t know if jack mode was meant for all the tires off the ground.
It prevents the suspension from leveling, so yeah, you want to do that for safety when on top of the lift.
You will still hear it adjust, but it’s very minimal compared to ”normal” mode.
Cheers,
I pulled the F17 fuse (air suspension fuse) under the hood and it will just stay in whatever setting you had it on with no adjustments possible. You will get a message on the dash to service your air suspension until the fuse is placed back.
