2019 Ram 1500 Limited w/air ride 37 inch tire
Gmash
Has anyone successfully installed 37" tires on a 2019 Ram 1500 Limited w/air ride suspension with the RC 5" lift? I believe they will fit, but not sure how much they will rub. Any information would be helpful. Thanks.
Theres a guy with a level and 37s on a rebel. It will fit as long as your offset isnt crazy. 0--18 should be fine.
Thanks for the response. So probably the recommended -5.5 would be ok.
37s will fit only if it’s stock wheel or stock specs of your OEM 22s, with that you will need a 1/4 inch spacer.
I don't have the 22 inch wheels. I would also be purchasing a wheel and tire package.
Hey, this reply might be a little late to the party, but I have this exact set up. Started with 35s and they just looked too damn small. I went with the toyo atII in a 37x12.5 and it fit perfectly with minor trimming, nothing a sharp pair of scissors can’t handle. Not much of a difference in performance jumping from the 35 to the 37 with the 3.92s.
^^^. Is this paired with a 6” lift ?
^^^. Thank you kindly for responding back with this. :)
I just had the 5” RC installed on my 2020 w/ air ride and I’m running 325/60r20’s (35.5x13) on a 10” wheel. To me it’s the perfect look. 35’s looked a touch small and I didn’t want to run 37’s. I’ve had to do more trimming than the sticky posted here. I just finished my third round of shaping and trimming and hopefully got it. I tested at the parking garage at my office yesterday. I have about 3/4” before I hit. I did test it in entry exit mode and it rubs pretty bad.
Do you feel that the 1500 with 3.92 gearing is fine with 37s? I am thinking about running 37s with a 4-5" lift. I am concerned about the gearing. Any comments would be helpful.
The 3.92s are just enough to move the 37s without feeling a ton of loss. Really not a huge difference between when I had 35s...I’d say go for it
Would love to see pics of the actual truck.
Cheers,
I would like to see a side view of it, also...
You my friend are a savior of lives.
