Anyone have 325/50R22 on limited?
Carlos.33193
Has anyone installed 325/50R22 wheels on the stock limited wheels?
Any issues with rubbing on the upper control arm?
Would this size even fit on the stock limited wheels?
Translate it to inches. Should make the search alot easier.
I had found that 35" by 12.5" would fit, but 325/50 is slightly wider (12.8") and wasn't sure if that .3" difference would cause an issue when using the stock limited wheels. I do have a 2" leveling kit but the upper control arm rubbing on the inside sidewall of the tire is my concern.
Reason I ask is, I can still get an XL/RF rated tire in 325/50R22, where as 35" by 12.5" R22 would only come in an E or F rated tired, which would cause more road noise, stiffer ride, etc.
Is that tire too wide to be mounted on a 9 inch wheel?
Thanks for adding the conversion - I hate metric sizes - i always have to find a calculator to figure it out. I think folks should put the inch size in parentheses so we can tell at a glance.
Also note that different tires are different sizes meaning the 325/50 might be slightly different in size between brands and tread types.
Ive seen them posted. i was planning to do the same when i need new tires. Let me see if i can find the saved picture.
I'm running 305/45R22s now, it's a 12" wide tire that is safe for 9" wheels. I'm looking for something a little bigger in both width and overall diameter, though as there is a big wheel fender gap in normal and higher modes.
I saw one post of someone running the 325/50R22 nitto ridge grapplers, but it damaged their suspension sensor due to the width. But those are about 1/4" wider then other brands 325.
