Air suspension switch
Nukegm426
Long shot here but does anyone happen to have the part number for the air suspension switch and possibly the matching harness plug? Not looking to add the actual suspension but thought the switch could be repurposed into an accessory switch that blends with the factory panel. Not sure if their different but I’ve got the 12” setup.
I don't think you can do that... It's not a "Switch"... It's computer regulated... You move the button, the computer then send a signal to the Air suspension module to do whatever you asked it to.... It's not a positive and negative switch.
You can buy the VSIM upftitter AUX switches https://www.idparts.com/aux-switch-panel-68231816ad-p-6310.html#pt_description thats a swap out from the 2500. The trick is getting it to work and all the relays. It also does not AFAIK have the toggles switches, they are all buttons. No idea if the air suspension would work.
interesting... the button style is different than the toggles that it has now but this is something to look into, thanks
