Need offset help
Chuck19
Southwest Florida
I am trying to decide on whether or not i need to get a 0 - +1 offset or a +18 - +20 offset.
The look i want is just a very slight poke to flush stance but am getting confused by looking at other setups. Some with 0 offset look like they are perfectly flush and some looked tucked and some +18 look flush and some looked tucked so i cant seem to get an accurate consensus.
I believe i have read that the stock wheels are +18 and with my current tires being 10.8” wide they seem to fit flush so i am really confused. I am planning on sticking with the same width tire just going up tp 33” tall. I need this setup to be as close to factory as possible MPG purposes so dont want the wide 12+ inch tire width or heavy LT tires.
Can i get some opinions here on what you guys recommend to achieve my desired look?View attachment 52729
What truck is it?? Need to know if it’s got fender flares or not. My truck is 20x9 with 0 offset hostile fury wheels with 11.5wide Nitto ridge grapplers. Here are some tire poke pictures. Keep in mind I don’t have flares. I’d recommend browsing through customoffsets.com gallery to see what different offsets and tire widths will look like.
Thank you very much sir! This is very helpful! I have looked through CO many times and kept seeing some that look perfect with a 0 offset and some that look tucked. Never had an issue like this before modding a truck or car for that matter but i kept seeing conflicting pictures of setups.
Forgot to mention they will be going on a 2019 Ram Quad Cab Bighorn 4x4
Just for my edification why do you say that?
Never thought to ask if you've got factory flares or not. Now I'm thinking you don't? My tires w/ flares are about an inch inside the flare. The difference between the 2 offsets is ~3/4". If you like the stance you've got now go w/ positive offset, If you want a little poke go with the 0.
No flares, so should look just like z0n3 setup hopefully!
Do you have any side pics? Would like to see your total setup!
Went with 275/60/20 Nitto Ridge Grapplers on Fuel Warriors 20x9 with +1 offset. Hoping I have no issues with that combo like rubbing on a completely stock suspension. Really don’t want to lift or level this truck.
Mine mounted measure an inch less than their spec'd, you should be fine.
