Looks good, are those the alpha Rex headlights too? How do you like them? Did you put LED bulbs in those too?I just switched out the bulbs with LED bulbs and have no issues. Here's a pick with original and new
The bulbs inside OEM LED fog lights and headlights are not replaceable.Going to bump this because I can't find an answer in my searching. For those with OEM LED fogs, are they really dealer service only? I stupidly bought a set of H11 switchback fogs for white/yellow use before checking my truck, and they are obviously not going to work with the Rebel OEM fogs. Do I have to change to a completely new housing to get use of aftermarket bulbs?
yes, you are most likely going to have to switch housing, or sell/return the switchbacksGoing to bump this because I can't find an answer in my searching. For those with OEM LED fogs, are they really dealer service only? I stupidly bought a set of H11 switchback fogs for white/yellow use before checking my truck, and they are obviously not going to work with the Rebel OEM fogs. Do I have to change to a completely new housing to get use of aftermarket bulbs?
What are your plans for the bulbs? I'd be down to maybe buy them, or even trade housings if you want the halogens and it's just plug and playThanks guys, that's what I thought after getting under the truck and looking. I wanted to get the yellow/white option without having to have a light bar, but I guess I'll try to get a low profile light bar solution.
@WXman, the trucks with the OEM LED fogs appear to have everything inside the housing driving 2 small LED boards, so there are no bulbs to replace. The fogs themselves are great, I just wanted the yellow option of the switchback.
I sent them back the next day. Prime shipping/returns, so I just said the description was wrong because it stated they'd fit the truck. They WILL fit a 2020 Ram 1500, just not ones with the LED's.What are your plans for the bulbs? I'd be down to maybe buy them, or even trade housings if you want the halogens and it's just plug and play
I think i saw on here somewhere, somebody makes a tint you can put over your lens to make them yellow.I sent them back the next day. Prime shipping/returns, so I just said the description was wrong because it stated they'd fit the truck. They WILL fit a 2020 Ram 1500, just not ones with the LED's.
