bigoldthor
I know there are lots of fuel/octane threads out there, and I've read most of them. But I haven't really seen these two particular issues addressed directly, or I just missed them.
1. Do you make it a point to use only Top Tier fuels, as long as you can get it where you are at the time? If so, will you pay a premium for it? I try to use Shell (or Marathon) which are both ubiquitous in my area. Others are not so much. I'll pay more for Top Tier unless it's outrageously more expensive, which I haven't really found to be the case. What I HAVE seen to be significantly more expensive are Top Tier 89-91 octane fuels that are free of ethanol/alcohol. They seem to cost $.50 or more per gallon than the 10% ethanol blends.
2. I know the manual recommends 89 (and that's what I have run exclusively up to now.) I also know using anything higher doesn't bring any benefits...you're just throwing your money away. But if a Top Tier 91 octane cost the same as a Top Tier 89 octane, would you care? Would you put the higher octane in just because they're both the same price and both are Top Tier?
