BiGJZ74
Finally received my 5100's in the mail today. Just waiting to install them as part of my Readylift 3.5" sst kit.
Good thing I made a signature finally today, and thanks so much for the info. That's great news. Looks like I'll just keep stock on there then! Any need to be concerned for CV angles or anything else from what you've seen? The wife brought up warranty concerns. Thanks for the help!Based on your signature, you have the factory 1" because you have the North Edition. I have the same, went with setting #5 and OEM UCA angle looks fine. Dealership did the alignment and said it looked good.
I sure hope so, they’re about 4x the price!
All kidding aside, I ran Billy’s for 180k miles on my last truck and they served me pretty well. There aren’t a lot of options out there right now and the Falcons look pretty nice. Can you purchase only the fronts? I don’t really feel the need to hit all 4 corners with a brand new truck
I don't think it really matters what you have on with the Readylift kit...I just took mine off. The ride is horrible unless you're only on smooth roads. Save up and get the 4in BDS...I'm amazed how good it is as I might swap out the fronts with the 5100'sFinally received my 5100's in the mail today. Just waiting to install them as part of my Readylift 3.5" sst kit.
Only off road I see is the occasional trailhead I mountain bike at. Money isn't the issue, I already own the parts so I am gonna give them a try. If I don't like then i'll take it off and go w/ coilovers. Thanks for the input.I don't think it really matters what you have on with the Readylift kit...I just took mine off. The ride is horrible unless you're only on smooth roads. Save up and get the 4in BDS...I'm amazed how good it is as I might swap out the fronts with the 5100's
If you're not offroading the coilovers are certainly an unnecessary extra 2K- One of the things that impressed me the most with the BDS was how much it improved my steering. I got used the the Readylift after a few thousand miles and you forget how changing the geometry just changes everything.Only off road I see is the occasional trailhead I mountain bike at. Money isn't the issue, I already own the parts so I am gonna give them a try. If I don't like then i'll take it off and go w/ coilovers. Thanks for the input.
I have yet to take measurements but mine to the eye looks level at #6. Every truck is a little different. Guys running the motofab 2.5" will be perfectly level and others say its a little nose high. I plan on doing the 1" to get some rake back though.Upon further inspection, I’m really curious about what is different From the other guys on here that seem to be happy with #6 or even #7. I guess it could just be personal preference, but I can’t imagine anyone looking at my truck thinking there is the slightest bit of rake. It is definitely nose-high. I looked at the strut and it appears he did in fact set it at #6, not #7. The more I look at it, I’m not sure #5 wouldn’t look too high without any rear lift. I’m considering changing to #4. What am I missing? Will the front settle quite a bit?
Yeah, that’s interesting. My white truck contrasts the black wheel wells more, so maybe it makes it look unlevel? Your black wheel wells, black truck, black tires...maybe it appears more balanced. I can’t imagine there is much difference between two non-ORP 1500 crew cabs w/ 5’7” beds, but maybe I’m wrong. At this point I’m definitely going to drop to #5, maybe #4.I have yet to take measurements but mine to the eye looks level at #6. Every truck is a little different. Guys running the motofab 2.5" will be perfectly level and others say its a little nose high. I plan on doing the 1" to get some rake back though.
Someone’s mentioned to me that even tho the wheel wells may be level, the lines of the truck make it look nose high. It’s because the bed sits lower than how the hood appears if that makes sense. See attached email from a vendorYeah, that’s interesting. My white truck contrasts the black wheel wells more, so maybe it makes it look unlevel? Your black wheel wells, black truck, black tires...maybe it appears more balanced. I can’t imagine there is much difference between two non-ORP 1500 crew cabs w/ 5’7” beds, but maybe I’m wrong. At this point I’m definitely going to drop to #5, maybe #4.
Yes, this does make sense. However, the bottom of the fender wells are NOT level. The way it sits now, if I drop it to #5 the wells still won’t be level. I’m beginning to wonder if there is something wrong. The shop owner installed himself and is very experienced. The Ram dealership actually recommended him. To top it off, he has a 4th gen Ram with a level. I can’t really imagine he did anything wrong, but I’m having a hard time understanding how the #6 setting has my truck so jacked up (pun intended).Someone’s mentioned to me that even tho the wheel wells may be level, the lines of the truck make it look nose high. It’s because the bed sits lower than how the hood appears if that makes sense. See attached email from a vendor
I highly doubt there would be much of a ride quality difference considering the ride height is only changed about .5" between those two settings. Mine set at #6 is perfect in terms of level/slight rake and rides great. Position #7 would probably put you nose high for sure.
Any chance you would be willing to take a measurement from the center of your wheel to the bottom of the front fender on your truck on setting #7. With my Big Horn having measured somewhere around 22” at the front and now is 25”+, I’m at a loss. Again, it’s on #6, not #7. The front is now 1.5” higher than the rear. That’s at least a 3” swing. I don’t understand what is going on.Yep that’s where I at I’m going to have to tear it all apart again damn it. Something told me not to do setting 7. I’m curious what setting people are using for just leveling it out
www.suspensionsuperstore.com
I know you said your truck is level at #6, but would you be willing to measure to give me an idea of where you’re riding from wheel center to bottom of fender? I still can’t understand how there can be such variation unless there is an install or product issue. The instructions note the need to “clock” the spring. I can’t see anything that looks off, so I’m wondering what are the consequences of not doing that? Presumably if the spring is not at the right spot it could ride high.Either that or leave it as is and buy the 1.5" rear spacer for $60. I know I would do that before another 5 hours of tearing the front apart again..haha
2019-2023 Dodge RAM 1500 2wd/4wd 1.5" MaxTrac Rear Coil Spacers - 1628
Free Shipping On All McGaughys Suspension. Best Price McGaughys lift kits and McGaughys lowering kitswww.suspensionsuperstore.com
