Motofab Lift / Level Kit 3" Front & 1.5" Rear
jj_kennedy
My truck (2020 1500) sits 1.5" higher in the back. I am looking at a Motofab Kit that lifts the front 3" and the rear 1.5".
From what I am reading its best to replace the Upper Control Arm when doing this. Is there a recommended brand or part for this that anyone else has used? I was looking at the Rough Country one listed below.
Also with this kit would I be able to fit 22x12s on 33s without having rubbing issues or having to trim any plastic?
The Rough Country UCA’s look awesome! I like the one piece design , as for the rims and tires you should be fine if you’re only doing 33’s, you could probably do a -44 and be fine but keep in mind if you ever want to do 35’s you would be rubbing with that offset
