Active and under bumper air dam removed
Why would you even remove them? kind of gains or something ??
And alittle bit of clearance too. Took mine off a month ago and no issues. There is a code but no light for it unless I scan it
Where is the plug for the active air dam ? my truck didn’t come with one but all the bolts and brackets are there.... almost like they forgot to put It on so I was thinking of adding one. Can you snap a pic of the wiring harness that went to the active air dam so I can see if I have that harness, if so maybe I’ll buy it from you.
I think I’ll be doing this as well. Looks a little cleaner this way. Combined with a lift/level it’ll give it a better look.
