Jako
License Plate Reverse light
I did LED bolt lights. Definitely brightened it up, clean look, and doesn't interfere with the tailgate.
Reverse light mod
Due to the poor lighting with the LED reverse light, I tried this today and pretty happy with the results. Let me know your thoughts... thanks! I don't plan on towing and if I have to, then it can be easily removed as I have installed quick disconnect connectors on the wires. The hardest part...
Another reverse LED idea
I just fixed the one area of this truck that bugged me. The reverse lights are too dim and I could barely see the curb when backing up. I bought these Soundoff Signal 4" LED pods. These are white only but they have 2 and 3 color models since they're designed for police cars. I didn't want to...
OEM LED reverse lights are absolutely terrible...what have you guys done to address this?
Finished, these are the Rigid Ignite diffused. Made a big difference! Really would like to see how you mount those on bumper in daylight. Thanks.
LUYED LED- New (Frugal) LED Reverse Light.
LUYED Reverse Light EDIT: Install instructions provided by the manufacture LUYED. Please install however you see fit.
Tapped into the 7 pin with supplied T connectors. 3M taped (supplied) to the bottom of the receiver. Install: -Look at your 7pin and look in behind your...
Adding low profile reverse lights! (Write up)
my luck, Amazon is showing it as "Currently unavailable". :-(
Can I add Auxiliary Lights to the Reverse Lights?
Well, since I have 8 weeks before it comes in, I have lots of time to learn and wonder about stuff. My last Ram was a 2000 extended cab 4x4 2500 sport w/ Cummins and that was back in 2000. I had a hard time backing up with tinted windows so I added auxiliary lights on either side of the back...
Bed Lighting Kit
Would these accesss be able to fit a CB antenna fitting through? Oh yeah look underneath plenty of spots
Which trailer plug wires to splice for LED reverse lights?
Have been trying to find the answer but not having any luck. Do not want to use a plug. Installing Rigid Ignite, that only have a red and black cable, no harness. Want a permanent install.
Reverse Off Road LED Lights
Just my own spin on adding some back up lights. Most people that I've seen do this have them hanging lower than what I would prefer, or seem to be flimsy. Parts List: LED's: https://www.amazon.com/dp/B00G620ZVU/ref=cm_sw_r_cp_apa_i_4Dy7DbE582VHH U-Bolt...
Reverse lighting upgrade
Love the Rebel EcoD and it's 25mpg around town, but one glaring (pardon the pun) inadequacy is the reverse lighting. Looked at the cube addons that some have used and the hitch receiver frame mounted lights, but wanted something less conspicuous. Settled on these and decided to mount them on...
Auxiliary brake light
Hey guys, I'm looking at installing 2 aux reverse lights...I bought the curt 56584 harness and I need some direction on what to wire where! Each light has a black and red wire...I attached a pic! Any help is appreciated!!!! Thx
Reverse Lights For 4th and 5th Gen Ram 1500 as well as TRX with Rear TRX Tow Hook Brackets
Our reverse light brackets are up for preorder at a discount. These work with any truck that has a rear TRX Tow Hook. The brackets mount to the rear two bolts of the TRX Tow Hook. The light is a Diode Dynamics SSC1 pod light with a red back light and white main light. for best results wire the...
Multi function rear auxiliary lights.
Hello all, I have a 21 ram. The aftermarket rear bumper has auxiliary leds, they are currently controlled with a switch in the cab. I would also like them controlled with the factory reverse lights. I was going to pick up the signal from the reverse lights and add it to pin 85 on the auxiliary...
💡 Upgraded LED Reverse Lights. Easy installation
The reverse lights on these newer trucks seem to be just for looks, they don't output any light. I was driving a customers truck in our parking lot and I simply couldn't see behind me. Its dark before and after work right now, and we've had a ton of success with these 8" lightbars, so we came up...
