Switching out big horn headlights
Kornfrk2727
Has anyone had there local dealer switch the stock lighting that comes with the bighorn 2020 ram to the optional premium lightning package? Found a truck with every option besides that one. Wondering if I should keep looking or ask the dealer to order the led headlights and swap them out. Thanks in advance.
moosem
Rhode Island
I did the swap as have others on this forum, as moparian said. It cost around $2000 total including OEM headlights and tail lights and aftermarket LED fog lights.
The tail lights are easy to swap, takes about 15 minutes. The head lights are a little trickier and require a fair amount of disassembly, but overall not too bad.
I doubt the dealer will do it because the headlights are not plug and play. It requires buying a third party adapter to get them to work.
richman1183
I doubt the dealer will do it because the headlights are not plug and play. It requires buying a third party adaptor to get them to work.
hey do you still have the part numbers for lights? I want to do this swap to mine.
moosem
Rhode Island
Here you go.
LED headlights:
Black:
Left - 68316089AG
Right - 68316088AG
Chrome:
Left - 68316083AG
Right - 68316082AG
Tail Lights:
Black:
Left - 55112993AD
Right - 55112992AD
All red:
Left - 55112991AD
Right- 55112990AD
You will also need this adapter:
Willwork4truck
SC
Those do look a lot better. $2K is steep but for the life of the truck they should be just fine.
RAM Patriot
Clayton GA
Willwork4truck
SC
That really looks good! The company website (used your signature link) indicated $620 ish for the set, that's certainly a good price! Did you do your own install and if so, how was it?
RAM Patriot
Clayton GA
The install was quite a challenge since you have to remove the grill, fascia and wheelhouse splash shields.
Plan on setting a day aside for this project.
I have some more details of the install in this thread:
https://5thgenrams.com/community/threads/headlight-assembly.16657/page-2
Moparian
Nations Oldest City
RAM Patriot
Clayton GA
Probably swap them out for a set of halogen equivalent LED bulbs(aka not cheap ebay ricer lights) and get a pretty good setup for less than a set of factory reflectors. That being said I would spend the ~1300 and get a set of LED retros from https://www.hidretrofitkit.com/custom-headlights/2019-5th-gen-ram-black-led-headlights/
I almost pulled the trigger on these but I could not justify the price and the ones with the DRL's are $300 more.
Moparian
Nations Oldest City
I do remember seeing that if you provide the headlights then the price is significantly cheaper(might have been on their FB page).
Mpickwith
I’m lookin to do the LED swap across the board on my 19 and the dealer is saying the LED Tail Lights will cause the Check Engine to stay on? Has anyone heard of this I couldn’t find anything anywhere about that happening? Headlights I get causing an issue without the harness adapter but not the tail lights.
moosem
Rhode Island
False. They are plug and play. Just make sure you get the correct versions. If your truck has BSM, make sure you get the ones with BSM. If no BSM make sure you get the ones that don't have BSM.
Mpickwith
thx that’s what I thought from everything I’ve seen just Wanted to confirm before I spent the $$
Mr. Hindsight
Are u leasing or purchasing? When I leased my ‘20 RAM I was told it was about $15 more per month to the payment for the premium lighting group. It was a no brainer because as soon as I saw the halogens I knew the premium led’s were the way to go.
Mpickwith
I bought it back in July but at the time I didn’t realize the premium lighting group was an option I thought it only came on the limited because that’s how the dealer inventory was where i bought and a couple others i price shopped while looking
Maverick4
Here you go.
LED headlights:
Black:
Left - 68316089AG
Right - 68316088AG
Chrome:
Left - 68316083AG
Right - 68316082AG
Tail Lights:
Black:
Left - 55112993AD
Right - 55112992AD
All red:
Left - 55112991AD
Right- 55112990AD
If you don't mind me asking, where did you purchase from? Interested in doing the same.
