22” Laramie Wheel - Largest Tire Height?
285/55R22 Nitto Ridge grapplers installed, i have the daystar spacers just waiting on the links to arrive to have them installed, as of now only have rubbing on full lock in normal mode, hopefully the leveling kit will fix that
Looks fabulous and I’m doing this exact set up!
my dilemma will be my beloved 2 inch wheel spacers. Do you think I’ll be ok or should I take them off?
Just got mine installed :)73CDADA2-365E-451A-855A-B5467D022D69.jpeg
I’m not sure about the spacers but with my setup above and daystar level kit on the front with revel links I have no rub in normal at all
Yeah I’m debating weather I should remove the spacers or do a little wet towel heat gun shaping
I've got air, so went with the front Daystar spacers and revel links for a ~1.5" front lift
Can you provide link for 1 1/2 inch Daystar spacers. I also have air and wil be getting revel links. Thank you
35's are about as big as you can go. I put on 35x12.5x20 Ridge Grapplers on the stock wheels and I get some rubbing at full lock in reverse; probably need to do a little trimming on the front fender liner. I also had to remove the dealer installed mud flaps from the front (see stock pic below). These tires aren't great on ice (as to be expected) but they ride nice at about 40psi. Stock tires are quiet but these aren't too bad. I can hear them on the highway but that's why you get the big a$$ stereo, right?
Stock:
No front mud flaps:
Revel sells the spacers also
Dang if I can find them but thanks. I’ll keep looking.
Thank you so much.
Stock:
No front mud flaps:
Do you have air suspension or steel?
Had the nitro RG 285/55r22s put on today. Not the best lighting in some, but I'll get better pics tomorrow. Limited 4x4, no ORP, front lifted ~1.5in with Daystar spacers and revel links.
Ive drove on em about 10 miles at Normal height so far, haven't heard anything rub.
I was concerned about noise getting a 10ply hybrid, but these things are super quiet. Ride so far is different but great, feels planted, minimal additional little bumps.
Aero I think
Aero
Normal
looka great, what is the height of the truck now? Can you fit in a 7 foot parking garage?
What leveling kit are you running?
Wheel Spacers
Daystar, Dodge Ram 1500 2.5" Leveling Kit, https://www.amazon.com/dp/B001GH1NHU/ref=cm_sw_r_cp_api_i_w6N-EbNWM0C67
