RPM on HEMI with 3.21
Pedja
What should i see on the freeway at 65mph / Mine is almost 1900 !
Pedja
New body, 5.7 l hemi stock tires 8 speed tran.
Wheeler
Activate show current gear in cluster. Make sure you are shifting to 8th gear. Also make sure tow mode is off.
Pedja
The exact rpms with 3.92, 8th gear, 275/65 18 is 1789; 3.21, 8th gear, same tire is 1465, both at 65 mph. So, you either aren't running 65 in 8th or you have 3.92.
Maybe they install 3.92 and window sticker state 3.21
WW2
Has to have 3.92.... thats the only thing that makes sense..its not impossible that the wrong rear end was installed at the factory. Stranger things have happened
