2020 Limited Black Edition w/ door mouldings
An you get some close up shots of what you’ve done please ?
Welcome and Congratulations on your new 2020 Black Edition Limited. Nice job on the side moldings! (y)
would you consider making some For another owner? If so how much $?
The factory mouldings are pretty expensive by itself. If you really wanted them I might consider doing a set. As far as a price, I wouldn’t know where to begin?
Looks great! Off topic but what tires u rolling?
Hankook Dynapro AT2 305/45/22
They ride really well. I was expecting more road noise from these vs the factory Goodyear’s. But surprisingly, they are pretty quiet
For those who have the limited black edition, I added the door mouldings. Although I couldn’t get them in black, I ordered the pieces and wrapped them with vinyl. Turned out pretty good. View attachment 45093
What vinyl did you use? I asked a shop that wraps vehicles and they said they could do it, because of the inlay "limited" had some roughness to it and the vinyl wouldn't stick.
Avery SW900 197-O Satin Black... https://www.amazon.com/dp/B07N9V2G88?ref=ppx_pop_mob_ap_share
Here is what I used. I had just a little bit left over so this was enough to cover the 8 pieces. As for the limited word, yes it doesn’t completely mould all the way. I tried using a needle to release the air trapped but it still laid pretty good. Personally I’d rather it not be completely moulded because I would think dirt and dust would accumulate in that area. IMO The satin black matches the blacked out emblems pretty well. Hope that helps.
Thanks!
