What is everyone using for stake pocket hole covers
hdvespa
So what stake hole pocket covers are you using to cover up the rear pocket holes in your 2019/2020 Truck.
AdventureJunkie
These were the ones I purchased. They have held up pretty well through heat and cold so far and havn't noticed any water seeping through them or around them. Cheap enough that if they go bad I'll replace them.
RJS
I'm using the same ones and they fit very well and don't leak. Had to buy a second set as when I tried to remove one it shattered, they are printed plastic and pretty hollow. Just an FYI because I'd buy another set as they look like they belong there.
RJS
Why should one do this
- Looks better
- I ran wiring up through the post channel so it helps protect it from the elements
- There are a couple holes in the post channel that can let water in if you have a tonneau
- Did I mention it make the rails look better and finished.
rgberg
Bay Area, CA
Wakesnowb
I am using the same, they fit great.
hdvespa
Thanks for everyones input. I'm going to purchase the set suggested off of Amazon. I agree that it will look cleaner having those covered once I install my tonneau cover.
Gen3CoupeTX
I used the same ones, 3D printed ones bought off Amazon. They fit great, finish the rails and look right with my Lomax tri-fold cover. Cheap and makes me smile ... I'll take it!
Tred's
Kansas City, KS
I bought mine off Ebay. It also keeps the water out of my bed with the tonneau cover rails not quite covering my stake pockets.
spinxt
Bull Ring is the way to go. They make a low profile stake pocket mounting ring that pushes nicely out of the way when not in use. They are available in chrome or dark chrome. They also come with a router bit to nicely cut out the plastic stake pocket covers that come from the factory. I’ll don’t have a close up, but you can see what they look like in the pics.
2019REBEL
ON, Canada
I got the same ones off Ebay, ordered them before I even had my truck :giggle:
WA-G
Troy, AL
Has anyone tried the low profile Bull Rings with a Retrax tonneau cover? They look thin enough to work without lifting the cover too bad. The trim bit would probably trim the cover too but I had to cut into the tonneau.
rsmeanie
Bay Area, CA
Bought the 3D printed ones I saw on this post. A little on the pricey side but they look great. Perfect fit and finish.
V8Spock
I have the Bull Rings with the RetraxOne MX. Gun metal finish. No problems using them with the cover.
The Bull Rings are handy when you need a couple extra anchor points. No complaints.
ryant601
Bergen County, NJ
rsmeanie
Bay Area, CA
I just bought these on information that they fit 2019 1500's well. Hard to stomach $22 for plastic, but if they don't fit well I'll have no choice. They come today so I will report back
Those don't look like they would sit flush. Depending on whether you use a tonneau cover or not, it could cause a problem.
ryant601
Bergen County, NJ
They’re not flush but fit under my tonneau cover fine
