Blindspot sensor paint
spinxt
Painted my blind spot sensors with a peelable wheel/body paint by Duplicolor. Their metallic gray is nearly a perfect match to the RAM Metallic gray body color.
Can I see a pic from further back. I’m thinking I’m going to follow suit. I have the same color.
Have you experienced any detriment to the sensor sensitivity by adding this?
I have no performance issues with blindspot monitoring or rear cross path detection!
Here you go. Not the greatest pic of all time...
Did it lay flat like paint? I've used plastidip but it didn't seem to lay flat and leave a nice finish. Do you plan on using it on anything else on your truck?
Yes, but you have to use very light coats. And no I don’t have plans to use it anywhere else.
