2019 2wd Level Kit
MTLRAM19
Had the Pro Comp 2” level kit installed today on my 2019 Ram Laramie, turned out like my previous the 4th Gen. From my research most 4th Gen kits work for the 2wd. I’m pretty happy with the results, still off about 1” but that lets you load up the bed a little before pitching up. First pic is before, last two are after. Ride remains about the same. Steering radius improved slightly. Hope this helps other 2wd owners, seems like most posts are for 4wd.
Looks awesome even with stock tires...
I got the 2 inch level with 285/65R20 bfg ko2 tires.
At the time of change the tires cant decide between 295/60R20 or 285/65R20 but after searching and looking threads here at the forum i choose the 285s im really happy i did it. Heres some pics and by the way mine its also a 2wd.
Looks good. I want to do the 60’s vs 65’s to help fuel economy. Hopefully we can drum up some 2wd conversation. What level kit did you go with?
