Need help locating abs fuse
19 streak
Like the title says. I need some assistance locating the abs fuse. My son loves to go play in the snow a bit and i can't find the abs fuse anywhere on my 19. I pull it in my 18 no problem. Can anyone help with this?
F26-ESP module
Also runs traction control.
Not sure if it will cause any other issues, so many systems run off each other anymore. Let us know if it causes issues other than intended.
F26-ESP module
Thank you very much sir. I will try it and let you know. On my 18 it just throws a "service abs system" message until you put the fuse back in.
Just to confirm. I pulled f26 today and it works just like my 18 does except the 19 throws a message for service traction control, service abs system, and adaptive cruise control not functioning. Other then that we got to go play in the snow for a bit today and brought many smiles to my boys face.
Just to help some others. F26 is the correct fuse. It is located in the Power Distribution Center which is under the hood, on the drivers side, just behind the radiator, not the fusebox under the steering column.
What about 2020 same thing f26 power
distribution center location?
