XM Question
Rayzram
When I have XM playing and then shut the truck off, each time I start it the radio defaults back to FM Radio. Actually, no matter if I am listening to Satelite radio, or my usb thumb drive once I shut off the truck when starting back it always defaults back to FM. This normal or something I can make stop happening? Found nothing in the manual about this and how to stop it.
Did you happen to set the memory button for your seats with FM on the radio? I wonder if that is it?
Driver Memory Seats — If Equipped
This feature allows the driver to store up to two different
memory profiles for easy recall through memory buttons.
Each memory profile contains desired position settings for
the driver’s seat, side mirrors, adjustable pedals (if
equipped), and a set of desired radio station presets. Your
remote keyless entry key fob can also be programmed to
recall the same positions when the unlock button is
pushed.
I was having the same issue. The last update seemed to fix it.
This has somehow fixed itself. The issue no longer exists. Stays where I last had it now for some reason. Ooh well not broke, dont fix it right. I expect some minor hiccups like this from an all new product line.
