Stock Laramie Wheels
Stew81
Has anyone put bigger tires on these Laramie wheels? I'm having it leveled soon and don't plan to go too big on the tires... Most likely 285/60/20 Ridge Grapplers or TA2's. Maybe wheel spacers but I haven't decided on that yet. Just trying to figure out how these wheels will look with a bigger tire. I've seen lots of pics with the other stock wheels but not many with these so please post pics if you have them. Thanks!
Yeah im sure someone does.
I have 285/60/20 Ridge Grapplers on Limited Wheels - no level though
Thank you sir! I can’t believe there was only 1 truck with these wheels in that whole thread. They do look good with bigger tires though!
275 60 hope this helps a little. Not much bigger but I like it
285/65/20
Any rubbing? I settled on the 285/65/20 for install next week. 60 seems to be more common so I was second guessing myself...
FWIW - 4x4 Limited w Air Ride, Revel level and daystar spacers getting installed alongside
Also curious if there is any rubbing with these 34.5" diameter tires. Is there a level on the truck?
No level on the truck and only very slight rubbing on the mudguards which I trimmed - no rub now
278CC393-32AE-430E-8EA9-F58B945A5FFE.jpeg35x11.5 R20
Did you do any trimming or have any rubbing with the 285/60/20?
I have a slight rub at full lock that trimming should fix but havent trimmed it yet cause I keep forgetting about it cause its only rubbed like 3-4x since I put the tires on months ago
