tobyw
- Jun 21, 2019
Just finished my install of the BDS 4" lift, p/n 1638H. Overall it was pretty much what I had expected, having installed several similar kits on various makes/models. There were, however, a couple of subtle nuances that I thought others might be interested in...
First and foremost, I'm not sure what kind of tool exists to access them, but I certainly don't own it, and the two bolts directly above the differential pumpkin were a nightmare. I ended up actually removing the entire driver-side motor mount assembly, which the differential mount bolts to. Not a big deal, but not in accordance with the instructions and it took me a good 20-30 minutes of futzing around to finally admit defeat and find the workaround.
Here is the differential finally dropped, and you can see the motor mount still attached. I was able to get the front-most bolt about a third of the way out, you can see it partially removed, but there was simply zero-zip-nada access to the rear bolt:
Here is a shot looking up at where the motor/differential mount assembly came from:
The crossmember cuts were more or less exactly what I've seen on other similar systems:
The next surprise came when I was bolting the upper controls arms to the new BDS knuckles. I had previously installed a ReadyLift system with UCA's, and the ball joint they use in their UCA is just slightly too long to for the BDS knuckle:
I had to raid my bolt bins and find a hardened washer with an ID and thickness that would swallow the ball joint shank, and thus allow the castle nut to torque up properly.
The next issue, and this one was self-created, had to do with my previously installed AirLift 1000HD airbags. The new BDS coils are, obviously, longer than the factory coils for which the airbags were designed. To eat up the additional space, I took a page out of my Jeep bumpstop playbook and drilled out some hockey pucks to stack above the airbag:
Then using a large plate washer from an old Jeep rear suspension kit, I stacked the assembly above the airbag and stuffed it all inside the new coils:
The final issue, and it's not really an issue, was the front braided brake lines provided with the kit do not route very well to stay out of the tires. The banjo bolt block essentially dictates the orientation of the line, and in it's natural/relaxed state the lines just stay fairly straight and rub the inside of the tire. I whipped up a couple quick brackets to allow me to fasten the hose to the knuckle and well away from the tire:
Overall a pretty simple install. Took about 7 hours start to finish, a good hour of which was spent dealing with these minor details.
