5.7 Hemi - 87 or 89 Octane
ColoradoCub
Calirado
What I find funny is that buried somewhere in the owners manual it has this caution about using 85 octane fuel and a recommendation of 89. But no where in the gas door does it say what octane to use and no where on the display does it say what fuel to use. So say you rent one of these FCA vehicles with a Hemi, and you are used to driving vehicles with no octane requirement, how does one know? You’d think if it was critical they would put a sticker somewhere to indicate it, they do have a sticker that says no E85 but nothing else. Who dives in to the owners manual and looks for fuel grade requirements unless cautioned.
Willwork4truck
SC
What I find funny is that buried somewhere in the owners manual it has this caution about using 85 octane fuel and a recommendation of 89. But no where in the gas door does it say what octane to use and no where on the display does it say what fuel to use. So say you rent one of these FCA vehicles with a Hemi, and you are used to driving vehicles with no octane requirement, how does one know? You’d think if it was critical they would put a sticker somewhere to indicate it, they do have a sticker that says no E85 but nothing else. Who dives in to the owners manual and looks fuel drive requirements?
yep, at least a sticker on the inside of the door. How much can that cost, plus it's another way they can try to wriggle out of a warranty claim... you'd think they'd jump on that.
ColoradoCub
Calirado
I’ll be honest I didn’t even know that it was required until I found this forum. Salesman never said anything to me and I doubt very highly they used premium when the kid ran my truck over to be filled up at the dealership on delivery. Plus I live at 7000 ft in Colorado and we have 85 87 and 89, all I ever run is 87 and at a .30 per gallon premium it sucks. But I have towed our camper up over 11,000 ft passes with the engine screaming and averaging 3-4 mpg and I’ve never heard so much as a slight ping or spark knock.
BlckDT
Metro Detroit
Have been running 87 since I got her. Now with just about 10,000 miles I switched to 89 in the last 3 film ups.
Should I reset by disconnecting the battery overnight? Or do you think the engine will learn over the continued use of 89?
—-|||RAM|||-—
Phil
sent from my mobile device
silver billet
—-|||RAM|||-—
Phil
The computer does it automatically "on the fly", it senses the knocking and does what it needs to do in milliseconds or less to correct that. It doesn't "learn" or have a memory, it just reacts instantly in the moment.
Willwork4truck
SC
Ouch, 3 or 4 mpg? How heavy were you towing? I understand pulling the actual grade with the instant mpg display would be that low, hopefully thats what you were saying.
Timeless
SC
From Popular Mechanics Site:
Q:
I live in Arizona and use 87-octane regular. In Utah, Idaho and Nevada, stations were selling 85-octane as regular gas. This forced me to pay more for midgrade 87-octane. Is this the latest petroleum-industry scam to get more of our money? Will my car run okay on this bogus 85-octane regular?
A:
Octane is the ability of a fuel to resist knock, and high-compression engines tend to knock more. The obverse of that is that lower-compression engines can run on lower-octane gas. Air is thinner the higher above sea level you go. Less air going into the cylinders means less pressure at top dead center when things go bang. It's a lot like lowering the compression ratio in the engine, reducing the need for high octane. Cars will run just fine on lower-octane fuel when they're well above sea level--and all of those states are. Hopefully, by the time you get back down to denser air, you've burned off most of the low-octane stuff, and can refill the tank with higher-grade fuel.
R
Rob5589
Guest
Q:
A:
Hmmm, interesting. Thanks for posting. Like I posted earlier, I ran 85 through NV, UT, ID, and WY without issue. But, the elevation was about 4k and up so maybe that is why?? I did find it odd that NV stations stopped selling 85 the closer we got to CA. Then again, Reno is 4500+ so who knows. Maybe just an emissions thing.
ColoradoCub
Calirado
You read it correctly, I averaged 9 ish for the entire trip but going up the passes under load the instant reading was 3-4 all the way up, running around 4500 rpms.
ColoradoCub
Calirado
Q:
A:
im getting ready to do a road trip from colorado to Utah and I’m gonna run 87 on the way there and then 85 on the way back to see how much difference in performance and fuel economy there is. I’ll be over 6,000 ft for most of the entire trip so it’ll be a good test.
StuartV
Lexington, SC
I only have 800 miles on the engine, so I know I'll see better mileage after everything is broken in and re-learned to my habits. (see my posts in the 0-30 & 0-60 thread - I run the tank down to less than 75 miles est. left then fill
4 tanks .. 2 89+ .. 1 87+ .. and recently the 87 no-ETH.
You only have 800 miles, you fill the tank each time, and you've gone through 4 tanks.
So, you're only getting 200 miles on a full tank of gas??
Diamondback
Midwest
According to basic math, mmmhmm-ish - more like 280-295
I have 1/2 tank left of my 4th tank.
Tank isn't fully empty when I fill up. And, it appears I don't actually fill it up to the full 33 gals either -- had to take the rig in for the Fuel Door issue (spewing out of the truck).
I'll hit 1,000 miles this weekend and will still just under 1/2 tank.
R
Rob5589
Guest
280-295 on a 33 gal tank is horrible. How much are you putting in on average? Your fuelly icon says 10.5. Is that an average? And if so, what kind of driving?
rick_od
Central New Jersey
Ive driven my motorhome from Maine to Florida and from New Jersey to Colorado and any time i got gas with no ethanol i got about two mpg better mileage. Its a mpg killer. Point is, we all have to make sure we are comparing apples to apples. Maybe some of us bought 87 with ethanol and then 89 without. Im in NJ, i get the luxory of 10% ethanol in all grades. Lucky me.
Cortesio
Iowa
This thread can be debated forever. If RAM recommends 89 but allows 87, then feel free to run 87. If in the mts, pulling hard, towing, giving it a lot of throttle, maybe choose 89? If driving like me, or on flatter terrain, towing nothing and having an empty bed, than 87 is fine. I draw the line at 87, won't use 85...
A station down the road has E-15 88 octane and E-10 87 octane. Now I'm no chemist and that choice does confuse me.
I do use Costco fuel at times and happily put in 91 in order to allow a mix of the next tank with 87.
I ran 87 on the highway this last weekend and got about 21 mpg, then I put 89 in on the way back and got... 21. So who knows?
Sorry in advance for the wall of text that follows...
I think I can help clear the confusion up on how ethanol content affects octane rating. It's important to keep in mind that the number you see on the pump is an octane rating and not a measure of actual octane content. An octane rating is a standardized measurement of a specific fuel formulation's resistance to pre-ignition or detonation. It's possible to have no octane in a fuel and still have an octane rating because the blend of that specific fuel has an ignition characteristic that is measured in comparison to the standardized octane characteristic. Straight ethanol, for example, has an octane rating of 113 with no actual octane content. This is because ethanol is inherently harder to ignite than traditional gas.
As you up the ratio of ethanol versus straight gas in a blended fuel, the octane rating likewise goes up. Standard 85 octane rated gas mixed into a 10% ethanol blend becomes the 87 octane rated fuel most of us see at the pumps. Upping the percentage of ethanol to 15% is the 88 octane rated fuel you are referring to. E85 typically doesn't have an octane rating listed on the pump. The 85 refers to the traditional 85% ethanol content although that percentage can vary to as low as 51% because of issues starting engines in cold weather with the higher ethanol content. Fuel that is 85% ethanol will have an octane rating of 108 which is significantly higher than traditional formulations of 91+ premium gas.
Octane itself has no effect on power. More or less octane does not correlate to more or less horsepower a fuel can make in an engine. Similarly, an octane rating has no correlation to how much energy is available in a given volume of fuel. The only thing octane does is make a fuel harder to ignite and likewise an octane rating is only a reference to how hard that particular fuel is to ignite.
That begs the question, why would we want to make our fuel harder to ignite? Wouldn't we want it to burn more easily? While it's true a fuel that's difficult to burn isn't much use in an engine, having fuel that too easily burns or ignites interferes with the normal operation of a traditional 4 cycle internal combustion engine. Physics tells us that the piston in an engine does work on the fuel/air mixture during the compression stroke. The properties of thermodynamics tell us that pressure, volume, and temperature are related for a constant amount of a gas (state of matter in this case, not limited to specifically gasoline fuel). As the piston compresses, the volume the gas can occupy in the cylinder decreases. This necessarily increases the pressure of the gas. Because work is being done on the gas by the piston, the increase in energy from compression is stored in the gas in the form of an increase in temperature. You've experienced this same principle if you've ever noticed how air compressed in a compressor is warmer than the ambient air temperature (at least until the excess heat is transferred to the environment).
Every compression stroke of every cylinder causes an increase in the thermal energy of the fuel/air mixture inside the cylinder. For a standard fuel in a standard engine, the fuel is resistant enough to ignition that it can tolerate the increase in temperature and won't ignite prior to the spark. This is also why high-compression and/or boosted engines typically require a higher octane rated fuel. The more aggressive compression raises the temperature higher than a standard engine and can push the thermal energy of the fuel past the point of ignition prior to the spark. This can happen before the compression stroke finishes and can be destructive to the engine because the piston is being pushed up by the crankshaft and down by the ignited and rapidly expanding fuel/air mixture before crossing TDC.
On the other side of the cycle past the point of compression and spark, a separate but related phenomena can occur. An ICE really wants the spark to be the only source of ignition in the fuel. After reaching full compression, a spark is created and the heat of the spark ignites the fuel closest to the spark plug. As the burn propagates outward from that point through the fuel, force is evenly and smoothly exerted on the piston which drives it back down the cylinder and drives the rotation of the crankshaft. Hot spots in the cylinder wall have the potential to ignite the fuel touching it independently of the burn radiating from the spark plug. This separate detonation exerts a force that at least partially opposes the force of the desired burn. This is what people refer to when they say an engine is "knocking". Modern engines have sensors that detect this and will retard the engine timing to reduce the likelihood that detonation will happen. If the detonation is severe enough and exceeds the engine's ability to compensate, engine damage is likely.
The octane rating of fuel needed for an engine is determined by the engineers that design it. They calculate what the normal operating conditions of the engine are and what environment the fuel will need to tolerate without unwanted ignition. In our case, the engineers have specified the engine to run as designed on a fuel with an octane rating of 89 or greater. All this means is that a fuel with that octane rating will be sufficiently resistant to ignition to not cause detonation or pre-ignition under any normal operating condition.
So what about the manual saying 87 is all right but not optimal? That just means that the engineers determined that engine knock is possible with this fuel but the engine is designed to be able to compensate for it should it happen. Conversely, they determined that 85 poses a higher risk of knock or pre-ignition severe enough that it can't be compensated for and could cause damage.
This is where everything gets more muddled and why you'll see some people say they see no difference between 87 and 89 and why some people swear it makes a huge difference. If you're running 89, you're going to be on a pretty even standing with anyone else running 89. Under normal running conditions of the engine, 89 octane rated fuel should be able to tolerate any environment that exists inside the cylinder without igniting outside of the spark. But a lower octane rated fuel does not mean lower power or lower energy. There is just as much chemical energy in 87 as there is in 89. If your specific engine and environment and driving style allows 87 to run without knocking, the engine will not retard timing and you will suffer no computer-induced power or economy loss. It will run no different than it would with 89. However, if you do experience engine knock with 87, your engine will compensate and ultimately power output will be reduced. It's important to note that this reduction in power is the result of your engine artificially limiting itself and not because the 87 octane rated fuel isn't capable of producing the same power.
Now to throw ethanol back in the mix, why wouldn't we want ethanol blends that increase the octane rating of our fuel? Wouldn't we benefit from getting away from the 87-89 questionable zone and use ethanol to further increase the octane rating to where knock and pre-ignition would never be a problem? The answer is the same reason you will always have some level of reduced performance and/or mileage with an ethanol blend.
For the same volume of liquid fuel, ethanol releases less energy than traditional gasoline through combustion. This equates to making less power with the same amount of fuel and likewise needing a larger volume of fuel to make the same power. How noticeable the difference between straight gas and a 10% ethanol blend is depends entirely on how the engine is used and the environment it is used in. For example, city driving with lots of starts and acceleration will have a more noticeable fuel economy hit than cruising at low RPMs down a highway. The result of this is some people see significant power or economy improvements switching from ethanol blend to straight gas while others will have a negligible increase.
This all results in a simple answer to the question of what fuel should you run....it depends. The specific way in which we each use our trucks will determine what is most economical for us individually.
Let me share my experience with my last truck for example. I drove a 2016 Silverado LT with a 5.3L V8 for 40 months and 44,000 miles before trading it in on my new Ram. My driving consists almost entirely of a daily 80 mile total commute to work primarily on an interstate. It was flex fuel and I did a fair bit of testing with every fuel type I had available. Where I am, E85 is the cheapest fuel. That is followed by 88 octane rated E15 and 87 rated E10. Straight gas is more expensive and available as 87, 89, and 91/93. With E85, I would get anywhere from 12-14 mpg depending on seasonal formulation. E15 was about $0.15 per gallon more and I would get 16-17 mpg. E10 was an additional $0.10 per gallon and I would get 17-19 mpg. Because of local ethanol subsidies, straight gas is significantly more expensive. While I could get 19-20 mpg with any octane rated straight gas, the increase in cost made it less economical to run over E10.
So far in my Ram, I'm at a little over 2200 miles and I've run a few tanks of 88 rated E15 and 87 rated E10. E15 has given me around 15 mpg and E10 has been closer to between 16 and 17 mpg. There's not a ton of 89 around here anymore so I'll likely run a few tanks of 91 or 93 rated straight gas to see if my gains are enough to justify an extra $0.50 per gallon. I doubt they will be but data points are data points.
If you are more concerned with always getting the most power out of your engine, run 89 rated straight gas and call it a day. If you're like me and want the most economical fuel, find an app on your phone to track mileage and start trying different types of gas. Everything else being equal, straight gas with an 89 octane rating will get the best mileage and allow the engine to make peak power. Higher octane straight gas will give the same mileage and make the same power while being more expensive. Straight 87 rated gas will potentially (but not necessarily depending on conditions) reduce power and mileage but is still safe to use according to the manufacturer. As you increase the ethanol content in blended fuels, price will go down as well as mileage and peak power. Local gas prices and availability will dictate what is most economical for you to run in your truck.
Willwork4truck
SC
Thanks Cortesio for that info and research. Where’s the Cliffnotes executive summary section? (Last para). Should be a stickie for fuel questions!
I’ll happily use the 87 E10 then!
Diamondback
Midwest
Maybe 20-22 gals on average. I kept getting the Fuel Splash and didn't want that to happen ever again .. think it is fixed now
Less than 1 mile to work .. drive longer at lunch to get me some highway mileage (70MPH zone).
Tank 3 had 91 OCT and just under half highway mileage (Labor Day weekend).
I am running the RAM AIR and this next tank will go back to 89 for further testing. I will say the RAM AIR makes me enjoy the engine as if I had opt'd for the 3.92 rear axle. It definitely woke the stock system up for me.
I was supposed to go home (Indiana from Nebraska or KC, MO from NE over the Labor day weekend, but plans fell through). I'm hoping to get some good full-tank runs here for the holidays.
I'm still breaking the engine in and trying not to do it like I did the R/T, but it's hard NOT to hearing the exhaust and having fun with some co-worker Imports LOL
I'm not worried yet about mileage until I get all my testing done. Once I get that done, I'll get a basic Dyno and simple tune, then go from there.
Tim N
R
Rob5589
Guest
Interestingly, I ran my first tank of 89. With my usual driving I dropped from about 18.5-19 ave to 17.1. I just filled up today again with 89 to see if it was a fluke.
Cueva del Osos
I've written about my towing experience with various fuels in one of the towing strings.
Baseline experience for me in 4 months/6800 miles/3000 of them towing 5,000# travel trailer:
Octane made no truly discernible difference in my mileage. 87 wasn't any worse than 89 and 91 wasn't any better than 89 (for me).
Ethanol blend vs pure gas made no discernible difference in my mileage (contrary to my experience with my previous Acura)
Gas 'brands' made a HUGE difference in my mileage. Pilot/Flying J/Love's - all gave poor MPG for me. Valero/Centex gave REALLY poor MPG for me. Shell/Exxon/Mobil/Phillips/Texaco gave average MPG for me. Costco/Sam's Club gave average to better MPG for me (I was burning Sam's towing over Raton Pass...performance was excellent, but mileage was average...which probably means it was really good considering the grade). Speedway (which just bought all the 'Giant' stations in Santa Fe...replacing all the top tier brands with 'Speedway') 89 octane has been the most consistent performance/MPG for me.
All that said...there's a bigger MPG change between driving 70, 75, 80 and/or 85 than anything I've been able to attach to the gas being burned. When that Hemi is kicked up to 80 mph, I watch my MPG drop from 20.5 to 17.2
Diamondback
Midwest
What rearend ratio do you have (don't see a Signature Block on your post?) That makes a difference as well. (compare 3.21 versus 3.92.)
3.21 would get better mileage at say 80 compared to the 3.92 (because the 3.21 RPMs would be lower .. HOWEVER, one also needs to know what RPMs their engine powerband is and Cruising RPMs as well to know which axle ratio you choose. There are plenty of online calculators for helping one decide. Most choose the 3.92 for trailer towing to get them off the line. I chose the 3.21 since I do not tow and plan on making trips back home a few times a year.
Tim N
