New fender flares issue with spats
mike12193
Sorry for the long winded post:
I was looking if anyone could help me out with part numbers for the factory spats that go behind each wheel on non OEM fender flare trucks. Here is what’s going on. I have a limited that had the factory fender flares. I installed the rough country pocket flares and removed the OEM ones. Fit is great except the fact is that when you remove the factory flares the spats that go behind the rear of each wheel are shorter then trucks without OEM flares and they leave a very large gap. Definitely can’t leave it like that as it will collect all sorts of crap. See pics below. I was able to come up with the following part numbers but I was wondering if someone can confirm these are the right part numbers for non OEM flares trucks. My dealer is of no help as they said he has to order the ones based on my VIN. I know those won’t fit and I don’t have the time to run down to the dealer and grab a vin off a non factory flared truck. The only site I could find with pics of the spats gives a couple part numbers for each spat.
Here are the part numbers I came up with:
Spats
Front Fender Spat, Left
Product ID: 68349567AB
Product ID: 68275915AA
Front Fender Spat, Right
Product ID: 68275914AA
Spat-Rear Wheel Opening
Product ID: 68307196AB
Product ID: 68307197AB
Product ID: 68275919AB
If anyone has any info I would appreciate it. I want to get the gap closed up ASAP
hey are you going to be selling your oem flares ? if so i might be interested. as for the spats if i end up getting the oem flares i`ll have my spats i believe they wont work with the flares am i correct? them maybe your spats that came with your truck might work with the flare setup you had on your truck , maybe we can work a deal .thanks
I would be willing to sell them. You are correct you spats won’t fit you would need the shorter ones. As far as retro fitting the OEM ones to your truck the OEM flares clip into holes on the fender so you would need to figure out a alternate method (some guys on here have used 3M automotive tape). Just letting you know.
Mike
Mike
Yeah I seen that they had clips . And heard they were using 3m tape. So if you have them factory on your truck they put holes on your fenders to clip those in? Kinda goes to tell you how they have changed things .
Mike
Maybe you guys should swap spats when you buy the flares from him?
