Flowmaster Flow FX Direct Fit Installed
U
User_21239
Guest
Put on a Flowmaster Flow FX today. Black paint is where I tack welded the slip joint. Easy install, I ended up just removing the rear muffler hangar bracket, it was easier to remove the stock muffler that way. Last pic is of the bracket removed. Sprayed a little teflon lube on the rubber hangers and they came off the stock muffler super easy. Sound is awesome.
U
User_21239
Guest
Sound Clip from rear pipe:
